Subframe connector weights?
Hello,
I have the weights of ours if that helps you at all... I listed them below. All weights are per set
Tubular- www.umiperformance.com/2001 or www.umiperformance.com/2002
Mild Steel- 24lbs
Chrome Moly- 20lbs
Boxed- www.umiperformance.com/2000
Mild Steel- 28lbs
Tubular 3-Point- www.umiperformance.com/2003 or www.umiperformance.com/2004
Mild Steel- 35lbs
Chrome Moly- 31lbs
Hope that helps!
Ryan
Mild Steel- 24lbs
Chrome Moly- 20lbs
Mild Steel- 28lbs
Mild Steel- 35lbs
Chrome Moly- 31lbs
Hope that helps!
Ryan
Hello,
Mild Steel- 24lbs
Chrome Moly- 20lbs
Mild Steel- 28lbs
Mild Steel- 35lbs
Chrome Moly- 31lbs
Hope that helps!
Ryan
Mild Steel- 24lbs
Chrome Moly- 20lbs
Mild Steel- 28lbs
Mild Steel- 35lbs
Chrome Moly- 31lbs
Hope that helps!
Ryan
