need help with steering
had my car lined up sererval times but it still drives bad,follows ever rut or line in the road have to hold the steering wheel and be ready for it,need sum help to fix this,my car 2000 ss on my 94 z28 it drove way better never had this problem,it lined up to factory spec,i also have umi k-member and lower a-arms stock everthing else up front.
have you checked the hubs and tire rod ends?
Put the front end up in the air
Grab the tire in the 6 and 12 o'clock position and rock the wheel
If it moves, you may need new hubs.
If it does not move, the hubs are OK
Now grab the tire in the 3 and 9 O'clock position
If it rocks in and out then the tire rod ends may be bad.
If nothing moves, maybe it's the tires.
Not necessary. Whenever my tie rod ends go bad, the car tends to follow the grooves alot more than normal because they no longer hold the assembly exactly streight. BTW, when they get real bad the car gets really darty under heavy braking.
I'm going with tires too. Mine are skipped in their wear pattern. I made a dumb mistake running a slightly skinnier tire up front and now I can't rotate it to get the wear evened out. Now the car just walks all over the place. What size are yours? Does the car have any other tendecies floaty, oversteer,etc...?
And FWIW my 96 TA seemed to handle and steer better than my '01 WS6. And I still cant figure out why.
my tires arent the best,have all new frontend dont think its that,275 40 17 tires kumho,ill just get some different tires and have the alinment checked again.when i got the car it had 1 dunlop and 1 fuzion on the front pulled a little to the right but tires lasted 2 years on the frount,these only 1 year and been lined twice once when put on and again when new k-member lower a-arms where installed.thanks for the help.
