Anybody else squeeking with a new Koni/Strano setup?
I installed the 4/4 Konis with the Strano Springs about a month ago, and whenever it gets below 40 degrees, they squeek like crazy on any bump. Any ideas how to cure that. I installed it all correctly. Where to lube, if lube were an option?
Clearence is just enough...I scrape sometimes over the speed bumps....but, not on regular roads. It's my rears sqeeking...could they not be tight enough?
LS1TECH Sponsor
Lube your swaybar bushings. Classic... When it gets cold the rubber gets hard. The lowering causes the bars to rotate away from where they always ran in the bushing before.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
They do not, because I don't find they hold up well. A bushing with a hole and a groove cut in is a point at which cracks start.
Grease them the old fashioned way...
__________________
When I installed my Koni's and Strano springs/sways, I used the lube from Energy Suspension on the sway bar bushings. It works very well. I haven't had any problems with it washing out and have had zero squeaks.
