how difficult to install aftermarket A-Arm's?
Hello,
Its not the easiest job but can be done in your garage with common tools. If you have some mechanical ability you will be fine. One nice this is we ship all adjustable items preset to factory lengths.. so there won't be any guessing on how to get them set and where at. We give you a good starting point.
If you are interested PM me a e-mail address and I will send over our installation instructions. You can also give Jerry in our tech support department a call and he will go over it.
Let me know. Thanks!
Ryan
Ryan
its very straight foward.... i did my k member and everything else in my driveway while on jack stands.
for lower a arms
1. get car up and take off wheels
2. undo sway bar
3. undo spindle from ball joint and gently hammer it out (may take some time just dont hammer too hard as you can damage the joint)
4. undo shock froma arm
5. remove a arm from k member
now the upper
1. undo upper ball joint and support spindle/brake assembly dont let it hang
2. undo upper strut mounts in the engine bay
3. remove entire assembly together
4. seperate the upper a arm from the stamped steel upper mount
5. start installing!
for lower a arms
2. undo sway bar
now the upper
oh one other thing make sure to get an alignment and the thing that manufacturers leave out is there is no provision on the lower a arms to use the correct tool to do your alignment. you may have to bring your car to a shop that does "special" alignments as i tried bringing my car just to my local town fair tire and the alignment guy was stumped cause he had never delt with aftermarket suspension like this. they are trained to use certain vehicle specific tools to adjust camber/caster. to ths day my alignment isnt dead on and is killing my front tires..i gotta find a chassis shop or someplace that knows custom alignments...
Can anyone else shed some light about this?
Thanks
I will send those instructions in a little. Thanks!
Ryan
Its simple, but the steering can get in way of the bolts for the lower a-arms so you may have to loosen that up to pull out of the way!
I wouldnt worry about uppers! They weigh more and a ton of 8-9-10 sec guys still use stock upper a-arms. Im going to do UMI lowers only.
Depending on how old your car is and how often you drive it in the rain, be prepared for that caster bolt to be very well rusted to the sleve of the stock bushing.
