question about relocation brackets
ok my current suspension mods are as follow.
agx kyb shocks
strano springs
umi adj phbar
umi adj lca's
now the problem i have with my car is that when driving on the street it feels kinda lose or like if the car just moves alot.
will getting some relocation brackets help that? i also have som vibrations and i hear that sometimes relocation brackets can help with that.
also next month im getting some koni 4/4 rear shocks
can someone provide some details on how their car felt before and after adding relocation brackets
agx kyb shocks
strano springs
umi adj phbar
umi adj lca's
Hello
Hello,
The lower Control Arm Relocation Bracket are designed to eliminate wheel hop and help gain back any traction problems due to lowering your vehicle!
Are you using a Sway Bar? IF so what kind?
Leave me know and I will be glad to help.
Thanks
Brad
Thanks
Brad
as for the sway bar i have stock ws6 sway bars
yea i have them set to the to the stiffes settings on the rear and thats where the car feels bumpy.
i will have to make sure that none of the bolts are lose or maybe im suffering from wheel hop.
either way im going with 4/4 rear konis soon so it should be all good
oh i have one more question...on your site where it shows the relocation brackets I see that he has the adj lca's install a different way than how i have mine...which is the proper way to have the adj lca's? with poly side on the relocation bracket or the other way?
Hello
Thanks for the questions, You want the poly end to be on the body of the vehicle and you always want the pivot able end on the rear so you have you adjustments and movement that you need. I hope that helps
Take it easy!
Brad
