no front sway on the street?
Old 02-27-2009, 01:28 PM
SS4Luck's Avatar
Default no front sway on the street?
im sure this question has been asked 10000000 of times but what can i hurt/how bad is it to not run a sway on the street? the car may see 7K miles this year and will be dedicated weekend warrior/ track car. Thanks
Old 02-27-2009, 01:41 PM
robsquikz28's Avatar
not bad at all just no wicked lane changes and like 70mph on highways atleast for me with no power steering
Old 02-27-2009, 01:53 PM
LS1TECH Sponsor
Sam Strano's Avatar
Please do a search... There is a HUGE thread about this. Some think it's fine, some think it's completely stupid (I'm in the latter group).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 02-27-2009, 05:37 PM
nemss1's Avatar
im running no front swaybar but im use to it and know my limits. not really a big issue
Old 02-27-2009, 06:42 PM
Randy WS6's Avatar
Mines been off for three years now, And i like it that way
Old 02-28-2009, 04:07 PM
Strahley's Avatar
Mine has been off for about 3 years as well, no problems here. I also run skinnies on the street, so I don't take turns hard at all. I also drive as far away from other cars as I possibly can
If you are a smart driver you shouldn't have a problem
Old 03-01-2009, 09:47 PM
02sleeperz28's Avatar
Whats a front sway bar? lol
Old 03-01-2009, 09:49 PM
02 BLK WS6's Avatar
No front sway bar, big rear sway bar
Old 03-01-2009, 09:56 PM
taws6m6's Avatar
I tried it, I didnt like driving a boat though
Old 03-02-2009, 10:28 AM
kenSS's Avatar
exactly.
Old 03-02-2009, 10:31 AM
1_bad_TA's Avatar
I don't run a front sway bar, no ps, and have skinnies. No problem at all.
Old 03-02-2009, 10:57 AM
Eagle02's Avatar
I ditched it a long time ago, but like everyone else has said - drive smart and it isn't a big deal.
Although, unless you REALLY will see benefit from losing ~20lbs (or whatever the stock SB weighs) just leave it on the car and rest assured that you're not really hurting yourself either.
-Eagle
Old 03-03-2009, 02:01 AM
FlashLCD33's Avatar
-Eagle
Weight isn't the main benefit of removing the swaybar. Removing it lets the front end come up without the drag of the swaybar bushings and twisting the swaybar itself. The more the front comes up, the better!
Old 03-03-2009, 10:41 PM
nemss1's Avatar
^^^yup, endlinks keep the front frm coming up so much. removing the endlinks gives the same effect as removing the swaybar but removing the swaybar knocks out 2 birds with 1 stone, weight transfer and weight removal
Old 03-03-2009, 11:00 PM
DTB_LS1's Avatar
I've taking the front swaybar off my old LT1 car and my current LS1 car and it's not bad at all. Between the two cars I've driven for about 10 years with no front bar and haven't had a single problem. You just have to remember that it's not there and don't plan on any fast high speed lane changes or road racing.
Old 03-11-2009, 11:59 AM
krwyellowZ28's Avatar
Not always true. It takes time and energy to lift the front end of a car. A properly tuned suspension will yield very little front lift. However, a mostly stock F-body will get better traction from front lift due to no front sb.
Old 03-11-2009, 12:18 PM
Dragkid1917's Avatar
Well i took mine off, seemed fine untill I was on 95 outside of philly and some serious **** went down infront of me. Spun out, hit the wall, building a new car now. Its fine 98% of the times, but that one time you really need to avoid something on the highway good god damn luck.
Old 03-11-2009, 01:12 PM
z28bryan's Avatar
That's the problem. It's sudden snap oversteer that causes the main issue. 99.99% of the time no one is going to notice anything other than the front feeling more disconnected from the steering wheel. Good luck when this situation occurs above to all who have no front swaybar....
This stuff has been covered in the past time and time again. Everyone's an expert though because they've "..tried it and have no problems.." so that makes you an expert and entitiled to give advice on the subject right?
Time to start a new 100 page thread!
Old 03-11-2009, 09:02 PM
LOL
