Question about Koni's and springs
Well I just purchased a set of Koni's from Strano's website. I actually just bought the rears and plan on getting the fronts with the next check, this is the only way I think I could force myself not to spend the money on something else. I bought the off-car adjustable kind due to price as well as the fact that I do not picture myself ever adjusting them. Here are my questions:
-What setting should I set the rears at before I install them?
-How inpractical would the highest performance setting be?
I am currently on stock shocks with 100k miles so I imagine even the stiffest setting would be a better ride than I currently have.
-I do not think I would want to mess with the front shock installation but how tough would the rear installation be?
I have access to all the tools I would need it is just a matter of finding the time with med school and work. But, what do you all reccomend in terms of springs? I currently just have the stock springs on the car with 100k miles on them. I do not want to lower the car any at all (low hanging SLP headers and true duals) but if my springs are shot I would definately like to replace them with something to complement the Koni's. Would I be fine keeping the ones I have, should I get OEM replacements, or should I get something aftermarket like Stranos?
Sam Strano highly encourages those who've purchased from him PM or even give him a call. I mention this from experience because when someone buys from him, he goes to great lengths to support his items.
Here are some installation instructions for the shocks, there are some on www.ls1howto.com. Just remember that the instructions for the rears on the website don't have to be done that way (there's another method that's much neater and quicker).
AFA springs go, well... yeah, I'd say stick with stock if you don't want to lower (or maybe not lower too much) or Strano's.
I also set mine to full soft.Yes it is a good idea to call Strano.He is a great guy.He recommended I set them to full soft.
________________________
2000 t/a ws6 with lots of mods
I had my rear konis set at almost full soft and the fronts were setup at about 4 sweeps from full soft (9 approx total sweeps from soft to firm) i had to soften the front some and stiffened the rear to approx 30-40% (1 turn from full soft ) keep in mind i have the 4/4's but with mine set almost full soft it felt like i was in a rodeo until i stiffened the rear. The back end bounced alot. front was really stiff also. But now it rides like a champ. I recommend also that you call sam he will help you get squared away.
LS1TECH Sponsor
If there is nothing wrong with them (not sagged) then they are fine. Keep them. And regarding the rear shock settings. Without fronts, you don't want to run anything more than full soft in the rear because you don't have upgraded damping in front to match.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
he mentioned he would be getting the fronts also thats what i gave him a heads up. Also he will most likely have to pull them out and redo the settings when he does get the fronts thats what i was trying to get out. I do recommend the stock springs and koni's i just did a install and review of what i ran into when doing it. There is a good writeup on ls1howto.com for the install and sam will answer any questions you have im sure. i would also suggest doing the front and back in one shot.
