Question about trans mounted T/A
Old 03-10-2009, 10:30 PM
913MOTOR's Avatar
Default Question about trans mounted T/A
Im using the UMI picture as an example because it seems like the easiest setup to do what im talking about.
For us guys wanting to run an Xpipe and true duals, would it be possible to shorten the square bar some and make the 1/2" mounts a big longer and flip it over and give us that 2 inches or so of ground clearance to tuck the X chamber that much tighter?
Those that want a DS loop would simply just have to shorten the leg and I dont think that little bit of change would throw off the instant center or torque arm.
Old 03-11-2009, 07:23 AM
UMI Sales's Avatar
Thumbs up Exhaust Clearance!
Hello
We have had guys use the tunnel mounted torque arms without the DS Loop for true duels but there is not much room and the exhaust is going to be small and a lot of kinks in it. What we have figured out to be the best solution. Is run stock length Torque Arm with a Torque Arm Relocation Kit. And If you want the DS Loop it will have to be mounted separate off of the relocation kit. I hope that helps if you have any other questions leave me know and I will be glad to help.
Thanks
Brad
Quick Reply: Question about trans mounted T/A
