Brake bleeding a 99 trans am with TCS
Old 03-11-2009, 03:06 PM
99bluefirebird's Avatar
Default Brake bleeding a 99 trans am with TCS
Search doesn't seem to be working now, I tried.
Anyway, I have a 99 trans am with 4 channel ABS/TCS. I need to bleed my brakes. In they haynes manual it says this can not be done without the use of a GM tech2 programmer.
Is this correct? Why could they not be bled in the normal way?
Thanks
Old 03-11-2009, 03:33 PM
chavez885's Avatar
You can bleed the brakes, but you technically cannot bleed the ABS. All that means is you'll have a little bit of dirty fluid, not a big deal. Just make sure the reservoir stays FULL and you do not get air in the ABS, and you'll be fine.
Quick Reply: Brake bleeding a 99 trans am with TCS
