new 2002 trans am- ruff ride!
My 02 trans am , has zero rated tires, I bought this car with the tires and thats what I was told- At high speeds 70 plus the car seems to shake a bit and overall rides a bit ruff, could it be alignment and tire issue - or any other thoughts, i prefer a bit more smoother ride and I think a fast car like this shouldn't shake at high speeds? Thanks
Not a lot of information here.
No car should vibrate or shake at those speeds so something is wrong. Are the wheels/tires balanced? Could your rotors be warped? What psi are you running in the tires?
The overall "stiff" ride (i'm assuming jarring and choppy?) is most likely due to stock shocks assuming nothing is broken or worn out. Replacing the stock shocks with quality ones (not cheap over the counter replacements) can yield you smooth and firm BMW-like ride and handling.
It can be a number of things..front alignment, wheel balance (was each wheel balanced right?), bushings are worn, worn ball joints, maybe bad or loose engine-transmission mounts..
shocks that are usually worn out would cause your car to say up and down easily after hitting a bump or a dip on the road
You need to provide more information about your car for us to really help.
