Qa1 12 ways ..SETTING THEM UP!
Old 03-13-2009, 12:28 PM
N2SPEED's Avatar
Default Qa1 12 ways ..SETTING THEM UP!
275 front springs and stock springs rear...
WHAT SHPULD I SET THESE ON? OR HOW TO TELL WHAT I NEED FOR DRAG RACING.? CAR IS FULL WEIGHT......
THANKS FOR YOU HELP
Old 03-13-2009, 12:31 PM
Wnts2Go10O's Avatar
well, start at the bottom and work up for the fronts. the rears, id start at the middle
Old 03-14-2009, 11:06 PM
N2SPEED's Avatar
Default help
what am i look for in the front? travel? wheel lift? weight ?
Old 03-15-2009, 01:19 PM
mr_biscuitz's Avatar
I am cam only with full suspension, 12 bolt 4.10s, m6, drag radials, 275 springs in the front w/ single adj. in the front slammed, and stock springs in the rear with shocks. My best time ever was 11.90, but my car runs consistant high 11's. I have mine on 0 on all fours. I know that seems crazy but it works for me, remember all cars are diff.
Old 03-16-2009, 09:57 PM
BMR Tech's Avatar
The fronts I would start at 1-2 clicks from the softest setting and the rears about in the middle. Shock settings are going to vary greatly from car to car but this should be a good starting point.
If you want give me a call here at the office and I can go over your specific application and make a better recommendation for you
Old 03-17-2009, 04:52 PM
transaman98's Avatar
well I am glad I popped into this thread because I was about to ask the same thing. I also have the 275# springs in the front, but I am rockin the BMR rear springs in the back, and the qa1 12ways in the rear aswell as the front. The car is full weight aswell. Is the softest setting all the way to the left when the **** will not click any further?
Old 03-17-2009, 06:41 PM
Randy WS6's Avatar
Well i have about the same setup as you, I have my rears set on #7 & front on #2.but i well have to make some changes because I just in stalled a 4l80 mvb 4400 stall & Tubular Sphon K-member and upper and lower control arms, Sphon Drag bar ,BMR tubular cross member, and having my front WS6 rims narrowed to 5"
Quick Reply: Qa1 12 ways ..SETTING THEM UP!
