Rear suspension Creaking
When going over bumps the rear suspensions creaks. Its sounds as if the car is 50 years old. i have a 02 Formula with all stock suspension. I tried spraying silicon on the rear control arm bushings, however when it wears off the noise comes back. Any ideas on a permanent solution?
I had the same thing. It was the LCAs. I actually made a similar posting to yours. Try greasing only the LCAs and see if it makes a difference. If it goes away... replace them.
Heres a few options!
Hello,
We offer affordable non-adjustable lower control arms that feature grease able fittings. Below is a link of our non adjustable lowers to show you what I am explaining.
http://www.umiperformance.com/2015?category_id=119
If you don't want to spend that type of money I would look into some poly bushings.
If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
Thanks
Brad
Thanks for the help. guys. Anyone have a link for a write up on removing the rear swaybar?
I think i'll try that first. If that doesnt do the trick i'll replace my LCA's
