squeak sound...
Old 03-14-2009, 08:55 PM
Nick_Rapitis's Avatar
Default squeak sound...
i posted the other day about this sound coming from the rear passenger side, sounds like a squeaky door sort of...well to get a better idea of were it was coming from i went outside the car and pushed down on the rear passenger side quarter panel to see if it would make the sound...it did everytime it went down and up...bad shocks? maybe just needs to be greased? if so with what? any info would be great thanks!
oh yeah forgot to mention the rear suspension is stock
Old 03-14-2009, 09:01 PM
chaman's Avatar
The bushings must be all dried up, possibly worn out. Do this...take some WD40 and sprayed it up all over the bushings and see if it stops. Its not a fix of course but it will give you a head start. Good luck!
Old 03-14-2009, 09:04 PM
Greekey's Avatar
Nick it could be many different things. I would def. check your bushings on your lower control arms, your sway bar endlinks, then to your shocks. It could even be something loose under there. Maybe another thing to check is your exhaust connections that hold the exhaust on the car. I had a horrible squeak from the rear of my car when I went over bumps, and it was my exhaust. I used a spray lithium grease on one area at a time to narrow it down.
Old 03-14-2009, 09:06 PM
Greekey's Avatar
How many miles are the on car?
Old 03-14-2009, 09:07 PM
yeah i know it isnt the exhaust because i just did my cme and everything is right where it should be, minus the tips, they need some adjusting...i would bet its suspension related but not sure, i'll get down there tomorrow and narrow it down...wd40 or lithium grease? which is better?
is got about 67,000
Old 03-14-2009, 09:09 PM
Greekey's Avatar
In my opinion, wd40 never lubricates as long as a lithium spray. But again, this is just a problem finder not a solver. Just use it to find out whats sqeaking, then fix it.
Old 03-14-2009, 09:11 PM
so is the bad shock idea out of the question? or could it be the piece the spring is sitting in
chaman's Avatar
WD40 is not a solution....and is probably cheaper than lithium grease...
Old 03-14-2009, 09:12 PM
chaman's Avatar
Shocks usually go out in some other way rather than squeak.
Old 03-14-2009, 09:13 PM
yeah thats what i thought but i dont have a whole lot of experience in suspension...
Greekey's Avatar
Shocks are not out of the question, but I highly doubt its your lower spring seat. Just spray and pray
Old 03-14-2009, 09:15 PM
sounds like a plan lol...autozone or napa carry lithium spray?
Old 03-14-2009, 09:16 PM
Greekey's Avatar
I dont really deal with napa to much, but I know for a fact autozone carries it. Atleast mine does.
Old 03-14-2009, 09:17 PM
sounds good...i will post again tomorrow morning with my findings!
Old 03-14-2009, 09:18 PM
Greekey's Avatar
10-4 Lieutenant
Quick Reply: squeak sound...
