What size thread on LS1 brake master cyl, and ABS block?
Looking to get the right adapter fittings to install prop valve. Need to know what thread is on the master for both front and rear holes (i think they may be different). And what size thread for the hole in the abs block where the rear brake line enters.
Thanks
Thanks
I need a wilwood prop valve between the master cyl and abs block. I rather not have to cut, bend or flare anything, so if you could gather me the right stuff, or even assemble it so that I could just install it in place of my factory master-to-abs line, that would be great, just PM me a quote.
