Hose Mod, Strano Spring Related...
I have tried the search feature but it no longer brings up anything relevent or maybe I am not using it correctly...
Me and my buddy both installed Strano Springs on our Camaro's
He added KYBs at the same time and I'm on the stock DeCarbons..we double checked the pigtails on the springs to make sure they were pointed in the right direction...
Both of our cars are slightly taller on the Driver's side. My car measure 2.5 in DS to 2.0 in on the PS....
His measures in at .75 in difference from the DS to the PS.....
Could we do the hose mod on the DS and leave the Iso in the PS?
What have you guys done to remedy this issue?
Thanks for looking
Thanks for looking
Copied from THIS thread about half way down...
"if one side is higher then the other (in the rear), rotate the springs until they match postions with each other (the end of the spring is in the same postion on both). this should correct any difference in ride height. if not keep trying various spring postions to even it out. it worked for me."
I really don't know... I haven't ever swapped springs.. its like one of those things I just for one reason or another never got around to. That should be changing soon, I just ordered BMR's..
I however, when I read it, took it that you would turn just the one side so as to compensate for it..
I'm the buddy he is talking about. I just finished the install this morning and my driverside is .75" higher than the passenger side. It is really bugging me so i'm going to play with it tomorrow. I only drove the car around the block so we won't have a good comparison until later this week. I have riden in his car a lot and my car seems to be a stiffer ride than his. It took the speed humps on my street very well. A lot better than it did when stock. I'll post up a better comparison after we take a ride in both cars.
in the rubber thing on top of the spring there should be an indention for the little pig tail to slide into. after i put mine in (with the rear end still down) i wiggled it back and forth and i fell into place.
Also, I can't tell if either of you have an adjustable panhard bar, but if your rearend is off-center, it can make the lean (which is typical on the majority of F-bodies) worse.
-Mike
-Mike
LS1TECH Sponsor
Thanks for looking
Thanks for looking
It's not the springs and you can verify that just by swapping them side to side and you'll get the same result (if they are installed in the same orientation).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Sam thanks for your input. I'm sorry if I made it sound like it's the springs. I know this issue is common with the 4th Gen F-bodies and not the springs that are installed on them.
I was just just curious if there is a way to remedy this issue. I will try turning the LR pigtail backwards to see if that helps.
Thank you for your input
LS1TECH Sponsor
I don't think you did make it sound like the springs, just making sure nobody was thinking it was.
Try turning them and see what happens (measure before and after too--but wait until you drive it for the after, never measure staight off the jack).
__________________
