swaybar endlinks
Old 03-19-2009, 02:04 PM
redbadss's Avatar
Question swaybar endlinks
i just purchased some polyurethane swaybar endlinks for my car, do i have to jack the car up or do anything special to install these or just unbolt the old and bolt the new in?
thanks
Old 03-19-2009, 02:08 PM
SnakeStomper's Avatar
Don't you have to jack up the car to remove the endlinks anyway?
Old 03-19-2009, 02:09 PM
kenSS's Avatar
i would just support the rear with a jack so it will give you some leverage
redbadss's Avatar
o and do i have to take the sway bar itself off or just the endlinks?
Old 03-19-2009, 02:11 PM
7camaro7's Avatar
just the endlinks come off then put on the new and make sure only to tighten them till they slightly budge. don't over tighten
are you doing front or rear?
with the front I had to use my 6in c-clamp to help push the bar down and it is also a lot easier when the wheels are off
Old 03-19-2009, 04:20 PM
redbadss's Avatar
the rear, we got them installed now it was an easy install.
Old 03-19-2009, 07:58 PM
kenSS's Avatar
good job.
Quick Reply: swaybar endlinks
