relocation bracket install ?
In the directions(umi) it says to place the smaller of the bolts(can't remember the size, one was 7/16, other was 12mm) thru the top hole and thru the spacer.
I recieved more bolts than I needed from one of my kits had some extras and wonder if there will be any adverse conditions since I decided to use a bigger diameter bolt?
Both bolts fit but I just wondered why they included different size bolts for the same size holes?
You should have 4 bolts.
The bigger bolt will need to go through the sleeve on the top hole that bolts to the rearend.
I always just reuse the stock lower control arm bolts because I like them.
