What Torque Arm?
What Torque Arm?
Ok well since the search feature is haywire, i need some help.
Im gonna get a torque arm, but im not sure which to get..I'll rarley see the track..So do i go with a tranny mount or a Body mount..And what are the benifits and disadvantages of either or?...
Also since the car is dropped would i need to get a Adjustable or Non-Adjustable..
Thanks
Thanks
LS1Tech Premium Sponsor
Thanks
Thanks
I would suggest our full length adjustable with a torque arm relocation bracket. Taking the torque off of the tranny not only saves the tailshaft from breakage but our bracket has adjustment holes in the front so you can raise or lower the front of the torque arm. The benefit to this feature is it allows you to adjust how hard the suspensioneffects the tires. If you have any questions please give me a call.
Hello,
I also recommend a full length (stock length) torque arm for your application. I recommend this because the vehicle rarely see's the track... I see a body mounted torque arm being overkill for your application. Also since you are running true duals the body mounted torque arm would not clear with your exhaust set up... but the transmission mounted set-up would. We built our transmission mounted torque arm around a true dual system and in most cases our set-up offers additional clearance over the factory torque arm.
Please visit this link, the installation pictures show this arm installed with a 3" true dual set-up- www.umiperformance.com/2205
I recommend the adjustable since the vehicle is lowered and the adjustment will allow you to correct the pinion angle.
If I can help anymore please ask. Thank you!
Ryan
Ryan
+1 on UMI thats all I run, full rear set up from them and no problems cut a 1.8 60 ft on a bolt on A4. Also customer service is outstanding, grade A quality, and the price is right, just compare them to BMR you will see. Go with what Ryan suggested it will work out
I haven't seen any UMI pieces in person to compare, but I can assure you that BMR quality is top notch. Since I haven't had to use their customer service I can't comment on that, but I think that speaks volumes about their quality.
Ok..So is this a Performance Upgrade, or a Durability Upgrade?...Or Kinda in between..I hear alot of people having problems with a Adjustable TA..But since the car is lowered its a must to have correct pinion angle..
Every customer is going to have a difference is opinion on brand... people will be bias to a product because they purchase it and it worked for them. Mook99 had a good experience with us and you had a good experience with BMR... thats always good to hear that is what keeps competition alive. However just because Mook99 mentioned our customer service was top notch doesn't mean there was a problem...
Thanks for the kind words guys!
A torque arm would be both a performance upgrade and a durability upgrade. What sort of problems did you hear about adjustable torque arms? Setting them up? Since the vehicle is lowered yes we usually recommend a adjustable torque arm.
Let me know and I am glad to help. Thank you!
Ryan
Hello,
Ryan
Ryan
I already am dealing with Terrible vibrations but that is more along with my Rear end needing a rebuild and my Tranny..Those 2 will be done in the coming weeks, but since the car is lowered and the geometry is different, would that cause more or different vibrations to the car?
You are getting vibrations because you do not have the adjustable TA yet so your pinion angle is slightly off. The advice these guys have given you is golden, you need the adjustable arm to get the right pinion angle. If that is set right, you shouldnt have any vibrations unless there is something else unrelated to the TA. You do not need to get the relocating bracket, mounting to the tailshaft is fine unless you are dumping the clutch with slicks at the drag strip. It sounds like the UMI TA will work best for you because of your exhaust set up and application. Take it to a professional if you need help setting up the correct pinion angle.
Wel i heard that, adjusting the torque arm is PITA!...Also, that horrible vibrations come from adjustable TA, Because your changing the pinion angle, in along with the way the driveshaft is angled..the whole geometry basically gets changed.And could cause more stress on the Rear End because the geometry is changed..
Let me know if I can be of anymore assistance. Thanks!
Ryan
Get adjustable, my car never sees the track but you NEED the right pinion angle. Get help if you are not comfortable doing it.
If you are stock-ish power, a tranny mounted unit is ok. The relocation kit is better. The relo kit plus the TA will prevent any durability issues with launching and will noticeably tighten the rear of the car.
I prefer UMI but I know first hand that BMR quality is also top notch. You really cannot go wrong. You like Mercedes or BMW?
Why not put Konis on the front of your car? Bilsteins are NOT suitable for lowering springs, you are really doing yourself a disservice...
http://www.bmrtvonline.com/video_detail.php?mId=3788
The adjustable torque arms aren't too bad to set-up and once you get it set you shouldn't have to adjust it again unless you change the vehicle height. We ship our torque arm pre-set to factory length and you then make your adjustments from there with it on the vehicle. Its not bad at all and we will be glad to walk you through it. If you change the drive line angle too much then yes.. you can get vibrations. But as long as you go with the stock length torque arm you will be just fine and will not notice any negative effects. I would be afraid a non-adj. would not work well for you since it is lowered.
Ryan
Ryan
Thats whyy i wanted to purchase the TA..So i can do all the things at once..
Ok..Sounds good..So the Tranny mounted TA..Is good..But in the coming weeks im going to do a H/C/I Swap..Am i still ok, or do i need the Relocation..And if i do, will it interfere with my exhaust setup?..
I know Bilsteins are not good with lowered rides..I have Front Koni's im just waiting on The Strano Springs, no sense in doing things 2wice..
As long as you do not change transmissions the torque arm will not interfere and a torque arm relocation kit will not be needed. The torque arm relocation kits are nice but you shouldn't need it. The drive shaft being steel or aluminum won't matter either.
Ryan
