Pointers on Painting Calipers
You don't necessarily need to sand them down, however i recommend using a lot of brake cleaner and a good cloth to clean them up. The casting should be rough enough to not need sanding. I recommend Duplicolor caliper paint, the spray on with a clear works best if you can take the calipers off the car however if you do not want to go that far the brush on kit works great too but you have to give it 3-4 coats. I have used this many times and it works great!
Kleeborp the Moderator™
I'd personally recommend powdercoating, but that's just me. My painted calipers held up fairly well for ~4 years, but had to be touched up once during that time, and towards the end they were looking pretty sad.
As already stated, the prep work is key - they HAVE to be clean, and that takes a while.
paint them with real car paint, base and clear, and never have a problem. you need to use a high heat primer though. ive had mine done like this for 3 years now and they still shine like the exterior paint on my car. i also found that if you cant take them off, "dabbing" it on with foam brush works well, this is how i did my brackets. if you put it on thick enough, the paint wil level off and leave no marks, just real smooth.
