Rear spring issues
Rear spring issues
Hey, I just put new springs on all four corners of my 99 TA. Front looks sweet, right rear looks sweet, left rear is about .75 inch too high. Ive tried rotating the springs multiple times and nothing changes. It is properly in the perch up top. Ive driven it around so I dont think its gonna settle any further. The car only has 35000 on it and a clean carfax so I dont think its tweeked. Any ideas? Also how much lower will the hose mod make it and does that cause any performance issues?
Did you try rotating the passenger side rear spring?
If you didn't try that first, otherwise if you have do the hose mod then.
The "hose mod" (5/8" fuel/oil hose 18" long) on the drivers side rear, that would be a low cost option which would give you around a 1/2" to 3/4" drop.
