Prothane bushings
Old 03-31-2009, 05:35 PM
SS LeadFoot's Avatar
Default Prothane bushings
What are the advantages or disadvantages of doing these? I herd they make A LOT of noise is this true?
Old 03-31-2009, 05:38 PM
therealcreeper's Avatar
which bushings?
Old 03-31-2009, 05:53 PM
all of them. I would go with BMR since all my suspension stuff is from them.
Old 03-31-2009, 07:53 PM
Magic Man's Avatar
They don't make noise just transfer it inside.Firms up the ride and handling.
Old 03-31-2009, 09:08 PM
7camaro7's Avatar
If you want better handling, get some, they're good!
Old 03-31-2009, 09:13 PM
Foxxtron's Avatar
Depends on where they're applied.
AFA a location where movement is intended to be restricted, then it can be optimal. AFA a location where "articulation" is needed, then you should reconsider.
Many threads have discussions on where one should use rubber, poly, or rod-ends, however if you can tell which parts, then I can offer more specific advice.
Old 04-01-2009, 12:45 PM
same reason i asked, you are a wise man
Old 04-01-2009, 01:27 PM
vjo90rs8's Avatar
for handling
rear LCAs: rubber or rod ends (or poly/rod)
panhard bar: rubber or rod ends (or poly/rod)
sway bars: poly
torque arm: poly
tranny mount: rubber (mainly due to vibrations)
Old 04-01-2009, 08:23 PM
^ X2. although i feel that you can get away with poly/poly in the phb. it isn't subjected to nearly as much bind as the lca's. i guess it depends on how extreme you wanna go. poly/rod would be a tad better but poly/poly really won't create any problems.
Old 04-01-2009, 09:02 PM
cool thanks
Old 04-02-2009, 10:27 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Just make sure you keep them greased! I usually grease them every 2 oil changes or so.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
