Brakes only wearing on inside of rotor. - LS1TECH
Thread Tools Search this Thread
Old 04-01-2009, 01:00 AM   #1
antsls1's Avatar
Default Brakes only wearing on inside of rotor.
Why is it always that the inside of the rotor wears more than the outside. i have a 2000 camaro with rear wheel disc and my front and back pads were only worn on the inside. i have changed the front but i dont understand why they always only wear on the inside. could this potentially be a problem or is this normal?
antsls1 is offline   Reply With Quote
Old 04-01-2009, 07:46 AM   #2
leadfoot4's Avatar
Two things...The caliper are single piston, with the piston on the inside. This will cause the inner pad to wear a little more. However if the difference is wera is really noticible, make sure you don't have calipers with pistons that are sticking, and make sure the caliper pins are well lubricated, so the calipers float freely.
leadfoot4 is offline   Reply With Quote
Old 04-01-2009, 12:44 PM   #3
z28bryan's Avatar
This is only my own observation.... I had unevenly worn brake pads inside/outside before I ever did a caliper pin cleaning and regreasing. I have never had unevenly worn brake pads since keeping the pins maintained yearly.
z28bryan is offline   Reply With Quote
Old 04-01-2009, 04:42 PM   #4
Ping King's Avatar
check the slider pins. They may be stuck.
Ping King is offline   Reply With Quote
Old 04-01-2009, 05:46 PM   #5
agreed clean the pins and if that's not the problem it's the calipers.
Brakemotive is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Fbody C5 Z06 Brake Uneven Wear jrwilliams95z28 Suspension & Brakes 18 07-07-2014 08:17 PM
Brake Pad Install Question Vi3t Suspension & Brakes 7 01-29-2013 09:45 AM
Turning warped rotors, w/o replacing pads? 89StripeGT Suspension & Brakes 11 06-16-2011 08:03 AM
My tires are ruined cthorny528 LS4 Performance 30 10-19-2010 11:50 PM
LSA/LS9 S/C Shaft Wear - Engineering Response Ed Piatek Cadillac CTS-V 2004-2007 (Gen I) 1 11-23-2009 07:32 PM
Tags
brake, brakes, crotor, disc, insid, inside, iside, pads, problem, rear, rotor, rotors, wear, wore, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
