can you remove ABS box
Old 04-05-2009, 08:34 AM
charged 434's Avatar
Default can you remove ABS box
is there a way to remove the ABS box and keep power brakes. i dont need the box because i removed the rear end and put disk braks so it will not work now anyway. did not know if they made something to replace it but smaller
Old 04-05-2009, 10:03 AM
Magic Man's Avatar
There are some sponsors that sell an abs delete block that will do what you what and you will still keep your power brakes I've had one for years and works fine.
Old 04-05-2009, 11:03 AM
ShevrolayZ28's Avatar
SJM
http://www.sjmmanufacturing.com/
Old 04-05-2009, 10:26 PM
SJM Manufacturing Inc's Avatar
Thanks to the above posters for the recommendations. Ours kits completely removes the ABS controller and associated brackets. Each kit comes with an adjustable wilwood proportioning valve to control brake bias needs.
Specific link location would be
LS1 car:http://www.sjmmanufacturing.com/cam_...0Delete%20Kits
LT1 car: http://www.sjmmanufacturing.com/cam_...0Delete%20Kits
