Turning slotted and drilled rotors?
LS1Tech Premium Sponsor
Yes you can do it but a lot of shops wont just because they are drilled and slotted. I had a set of slotted we turned at a friends shop a while ago with no problems.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Most shops won't because it takes longer and it risks hosing up the cutting tool.
If you set the cutter depth to take off the "normal" amount of material per pass, many times when the cutter hits the leading edge of the gap created by the hole or slot, it will break the tool.
So, it requires the cutting depth to be decreased significantly, meaning more passes.
