QA1 Settings
Old 04-10-2009, 12:59 AM
AutomagicLS1's Avatar
Default QA1 Settings
I have some QA1's on my car and I am just curious where you guys have yours set at so I can find a base to start with. I need to start messing with the settings on them just havent gotten around to it. They are on a full weight car never at the track only on the street. Also I have 325lb springs on the front
Old 04-10-2009, 02:11 AM
GMmexican's Avatar
call umi and ask them
Old 04-10-2009, 08:57 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, do you have fronts and rears or just the fronts? Are they single adjustable or doubles? A good starting point for the single adjustables is 6 or 7 from softest for both front and rear. Keep in mind these are just a starting point.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 04-10-2009, 10:43 AM
Magic Man's Avatar
On the street I run rears at 6 and fronts at 3 just try and adjust for the ride you want or like.
Old 04-10-2009, 10:43 PM
blkbird_WS-6's Avatar
What about if you have double adjustables on the rear? Where would you set the rebound?
Old 04-10-2009, 11:53 PM
99Bluz28's Avatar
Lightbulb
I've had both QA1 SAs, and DAs frt & rr on my car before.
All adjustments are made from full soft.
For the street:
front:
QA1 SAs 4 to 8 clicks .
rear:
QA1 SAs 1 to 3 clicks .
front:
QA1 DAs Compression 4 to 8 clicks , rebound 10 to 16 clicks .
rear:
QA1 DAs Compression 2 to 6 clicks, rebound 9 to 12 clicks .
Old 04-12-2009, 03:15 PM
omcar's Avatar
Rear Qa1s are set at 4/4 for hooking at the track.
Quick Reply: QA1 Settings
