will lt1 brake lines bolt to ls1 calipers?
im swaping my k memeber and front suspension over to a ls1 set up for my ls1 swap. will the lt1 brake lines bolt up to the ls1 calipers?Thanks
We've got a hybrid braided line brake kit if you've only changed the front LT1 calipers to LS1 and kept the same LT1 rear calipers.
If you've changed to LS1 front/rear brakes, you're best bet is to change the rubber lines to new braided LS1 lines...the others are old anyways. We've got you covered in that area as well.
I called SJM to order the kit mentioned above and it is no longer available.
Does anyone know of a similar kit that offers brake lines for LS1 style front and LT1 style rear?
Thanks,
Ryan
Thanks,
Ryan
