To much caster? camber
I have my toe set at 0, camber set at 1.8, but what should i set caster at? can you have to much? 99ss Lg springs, sams frt bar, 1le rear bar, konis rear. i am looking for autox/RR setup. i have 0 uneven tire wear on the frts now and want to know if u can have to much caster and should i go more -camber if i have no tire wear.
LS1TECH Sponsor
You can't really get close to too much caster on a 4th gen, let alone one that is lowered. It's rate anyone can get to +5 degrees.... And you shouldn't need much more negative camber than you have (I can only get -1.8 and get good tire wear when racing). Definitely don't need more than -2 for track use IMO.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
I have a run of bars coming in about 3 weeks. A number of them are already spoken for. I'd suggest getting an order in sooner than later (no charge applied until the bars are actually ready to ship, the order just tells me you want them and to save them).
__________________
