Gabriel ultra shocks and BMR springs
Old 04-22-2009, 02:59 PM
94-z's Avatar
Default Gabriel ultra shocks and BMR springs
got the shocks awhile back and plan on lowering with bmr springs should they work fine or would they create a problem?
Also all that is needed to lower a camaro is the springs correct? anything else i should get while i am at it?
Old 04-22-2009, 03:16 PM
BandDirector Blk98ZM6's Avatar
I WAS planning to just run my stock shocks with my Eibach Pro-Kit, but then when we went to install the springs, we DESTROYED the front shocks, so I had to make a qwick trip to AutoZone for shocks and picked up the Gabriel's for like $130 for all 4. They've been on about 1.5 years and they're not that bad. I intend to get the "good" shocks eventually, but it's not unsafe or anything for now.
Springs are all you have to have to lower an F-Body, but LCA relocation brackets, and an Adj. Panhard rod aren't a bad idea to make sure you keep your traction and are able to re-center the rear-end.
Old 04-22-2009, 03:34 PM
dragonrage's Avatar
I like Gabriel Ultras on a regular old boring car, but they are definitely no good for an F-body, especially a lowered one. They're a little bit better than KYB GR2 and Monroe, in my opinion, but that's not saying much.
