Squeaking Brakes
Old 04-26-2009, 12:25 AM
Greekey's Avatar
Default Squeaking Brakes
Guys im a little confused on something. My brakes after being abused for a little while start squeaking, almost as though they are getting to hot. But when I hit the brake pedal it stops, but once I let off again the squeaking comes right back. So they are not squeaking when there is pressure on the pedal, only when im crusing. After a while, it stops only until I begin to use them with much more abuse. They are hawk hps pads, and they are not worn down. Any ideas? Thanks in advance.
Old 04-26-2009, 07:53 AM
sroach20's Avatar
pull the calipers, clean everything, regrease the slide bolts, and put some more anti squeal crap on the back of the pads.
Old 04-26-2009, 09:50 AM
Save the manuals!
wssix99's Avatar
Not brakes - its probably your wheel bearings/hub. The sound is coming from the front, right? (Our hubs sound just like squealing brakes when they are going out.)
Mine did this. When I took the brakes/rotor off and spun the hub by hand, it felt like a meat grinder.
Old 04-26-2009, 11:00 PM
kevin99hoss's Avatar
^ i agree with wssix99 my DD did the same thing when you apply pressure to the pedal the sound goes away, i had to replace the driver hub
Quick Reply: Squeaking Brakes
