Cons of the PHB relocation kit?
Hello,
The panhard bar relocation bracket can effect the handling in a negative way.. this is because it changes the angle of the panhard bar. However based on the pictures of your vehicle and your current modifications you are not going for a handling car. Based on your current set-up I feel you would not notice any negative effects from the relocation kit.
Here is a link to our kit- www.umiperformance.com/2024
If you have any additional questions please ask.
Hope that helps!
Ryan
Hope that helps!
Ryan
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F-bodySuspension.htm
I wish, got about $700 I can borrow???? lol
I have BMR lowering springs already with a set of Bilstein shocks/struts; BMR LCA relocation brackets; custom LCAs; UMI adj pan hard bar; and UMI trans mounted adj TA. I was thinking of going with a 22mm rear sway bar but wasn't sure if that will be beneficial for my all around driver.
true, forgot about that part, plus the increased weight probably outweighs any positives if there any at all when it comes to drag racing, (road racing is a completely different story though), one of the nicest camaros around man
the best thing for all that is going to be the watts link, but that does have the downside of price and extra weight....but it should give you the clearance you need for the exhaust, and give you much better handling in the corners, with no ill effect on drag racing other than the extra weight.
a pretty fair tradeoff in my opinion....just save up longer and get the watts link.....that's what i'm doing.
Thanks man!!!
