Help.. D/S hitting torque arm
Old 05-08-2009, 04:47 PM
Arc00TA's Avatar
Default Help.. D/S hitting torque arm
Okay I am stumped by this. Recently when I turn right I've been hearing a bad thumping/ratcheting noise, and I got my car on the lift and found that my driveshaft is hitting the torque arm right at the crown where the front U-joint is, the widest part. I have no idea how it is hitting, and it only happens when I turn right.
My suspension mods are:
UMI torque arm relocation kit
BMR non-adjustable torque arm
Poly/Rod end single adjust LCA's
Poly/ Rod end single adjust panhard
3 point SFC's
Poly sway brace links
I notice a lot that my axle feels like it is sliding out from under the car when I go through a sustained turn like an on ramp for a highway or something. Does anyone have any idea what can be causing this? There is only about 1/4" clearance between the driveshaft and the torque arm at that point where it is rubbing.
Old 05-08-2009, 04:53 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Are you using the inner or outer holes on the torque arm mount?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 05-08-2009, 05:05 PM
Arc00TA's Avatar
Off the top of my head I'm not sure, but I assembled it according to the instruction sheet that came with it. Could I have put the torque arm on the wrong side of the mount? Is that even possible?
EDIT: I just looked at the picture on the site and its the same way as there, so I think its on right.
Old 05-09-2009, 11:15 AM
Arc00TA's Avatar
Anybody else have an idea?
Old 05-11-2009, 08:31 AM
BMR Sales2's Avatar
Hey send me a picture of the way you have it mounted. otto@bmrfabrication.com
__________________
Glenn ***
Sales Tech
813.986.9302
