UMI Tunnel Brace Torque Arm Making Noise…. - LS1TECH
Thread Tools Search this Thread
Old 05-10-2009, 07:36 AM   #1
Fun-Formula98's Avatar
Default UMI Tunnel Brace Torque Arm Making Noise….
So…Under deceleration and breaking over bumps my new UMI Tunnel Brace Mount Torque Arm make s a “thud” sound. Anyone have this problem, or is it just me?
Fun-Formula98 is offline   Reply With Quote
Old 05-10-2009, 08:07 AM   #2
98Camarod's Avatar
Did you get the proper driveline angle?
Sure its not a broken trans mount?
98Camarod is offline   Reply With Quote
Old 05-10-2009, 08:14 AM   #3
0 degrees Stock ride height
Old 05-10-2009, 08:28 AM   #4
98Camarod's Avatar
Check your trans mount. Mine was trashed before and on decel it would bang like you are mentioning.
Old 05-10-2009, 08:31 AM   #5
Will do…BUT its fairly new… I replaced the stocker with an energy suspension mount.
Old 05-10-2009, 04:28 PM   #6
UMI? Any thoughts? PLEASE?
Old 05-10-2009, 09:29 PM   #7
stealth355tpi's Avatar
ive got the same problem. my mount is good and the angle is also at 0 degrees. but ive also got a spool so ive gotten use to the thud sounds. sorry i couldnt help but its normal from what i have heard.
stealth355tpi is offline   Reply With Quote
Old 05-10-2009, 11:44 PM   #8
metalmechanic's Avatar
i have all that new stuff to and does the same thing, its a trade off for better handling performance, I have BMR
metalmechanic is offline   Reply With Quote
Old 05-11-2009, 08:12 AM   #9
LS1Tech Sponsor
UMI Sales's Avatar
Quote:
Hello
The noise that you are hearing is the Torque Arms mounting bracket! Their are a few options to fix this. One is to relocate it to the second pair of holes (But you might have to grind some of the bracket off to get to clear the rear) and the second is just massage your tunnel for clearance (or let it go and it will make its own clearance) If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
__________________
UMI Sales/Tech
Customer support
support@umiperformance.com
1.814.343.6315
Craig Ext. 101
Ramey Ext. 102
UMI Sales is offline   Reply With Quote
Old 05-11-2009, 09:14 AM   #10
LS1Tech Premium Sponsor
UMI Performance's Avatar
Hello,
Another thing not mentioned is to make sure the bolts that attach the torque arm to the rear bracket are very tight. These are the (2) 5/8" bolts that run through the torque arm and attach it to the bracket that attaches to the rear end. These bolts are only installed finger tight by us during assembly. Did you tighten these two bolts? If you did please double check them... it takes a lot of force to compress the 3/8" thick steel mounting plates we use. Tighten these two bolts as tight as you possibly can. If there is any movement there this will cause a thumping noise.
Also what Brad mentioned is something to consider as well. Is your vehicle lowered? Do you have an aftermarket rear end? These few things make a difference.
Let us know and we will be glad to further assist you. Thanks!
Ryan
UMI Performance is offline   Reply With Quote
Old 05-11-2009, 10:23 AM   #11
Everything is TIGHT... Better handling and performance for a little "thud" now and then.... I can deal with that.
BTW... UMI has great customer service and their products are second to NONE!
Old 05-11-2009, 10:35 AM   #12
also just so you dont have the same problem i did, if you have an aftermarket rear like the moser 12bolt make sure u tack weld the 4 bolts to the torque arm that holds it to the rear. i broke the back half of the arm b/c those bolts came loose
Old 05-11-2009, 06:21 PM   #13
Thanks, new rear is coming soon... I have a few decisions to make first...
Old 05-11-2009, 08:36 PM   #14
Glad you are happy with the torque arm and service!
I highly suggest like mentioned to avoid the Moser 12-Bolt.. the Strange 12-Bolt is nice as well as the Strange S60 and Moser 9".. but those could be overkill.
Hope that helps!
Ryan
Old 05-11-2009, 11:15 PM   #15
silverLSWON's Avatar
typical tunnel mounted torque arms. they always make the thud noise
silverLSWON is offline   Reply With Quote
Tags
1996, arm, arms, brace, firebird, hearing, ls1, mount, noise, short, suspension, thud, torque, tunnel, umi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
