qa1 fnt coilovers
Old 05-10-2009, 09:52 PM
BuckaroooZ28's Avatar
Default qa1 fnt coilovers
anyone do the qa1 fnt coilovers? i got my parts in and it looks like im missing parts. Do you reuse anything of the car or old strut? btw this on an 02 camaro
Old 05-10-2009, 10:08 PM
99Bluz28's Avatar
Lightbulb
Lets see, you'll reuse the lower shock mount bolts/nuts, and the complete upper mount assembly.
Old 05-11-2009, 09:33 AM
birdmaro's Avatar
yeah its pretty easy. as far as the parts you received, the jam nut goes on first, then goes the spring cup. then the thrust bearings (BUY THE THRUST BEARINGS). then the spring. when you take out the old strut, whatever doesn't come with the qa1's...you reuse, which is basically the upper strut mounts and the lower two bolts like stated above. make sure you use the bolt that comes with your coilover for the top mount...the OEM bolt is a different pitch and WILL strip your strut bolt.
i didn't use the little boot inside the spring, mostly cause it doesn't fit in the new springs.
Old 05-11-2009, 09:31 PM
do you mean the nuts you get for the top of the strut cuz i didnt get any bolts
Old 05-12-2009, 01:04 PM
99Bluz28's Avatar
Thumbs up
Yes.
