Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Print Wikipost
Super Cheap Big Brake Kit - Info
Old 11-15-2013, 01:20 PM
  #441
myth's Avatar
Originally Posted by 01dropTOP
I personally dont know if they would fit but it says that you need 1 1/4" space minimum between the stock calipers and your wheels for the brembos to fit.
I think that is too much offset though, might need a small spacer if anything.
good luck!
Thanks for the response. From i have figured is that I would need a 5mm spacer or so. i just figured that since these brakes have been out for awhile that someone would have this setup.
I have had the brakes for awhile but have not bought the wheels yet. I managed to get one to fit under the 17" ZR1's that are on the car but did not like how far out i had to space the wheel.
Old 11-28-2013, 04:51 AM
  #442
Firebird T/A's Avatar
guys could u plz check these specs on this specific rims seems much like will fit without spacers right ? 40 mm offset!
http://www.oewheelsllc.com/Wheels_3/...5#.Upcby8QW2FU
thank you
Old 11-28-2013, 12:38 PM
  #443
JJsQwuik's Avatar
thank you
Yes the C6 spyders will clear since they have a 40mm offset. dont get the ones for camaro/firebird cause the off sdet changes to 53-56mm, then you will need spacers
Old 11-29-2013, 11:16 PM
  #444
No Juice's Avatar
Originally Posted by imma_stocker
Has anyone made a list of wheels that will fit without hub spacers? Or with X mm spacer?
I'm looking for this same list. Anyone been keeping a list ?
Originally Posted by mac62989
Most are using C6 ZO6 wheels but you can always go the custom route.
Which C6 Z06 wheel and what are the specs of that wheel ? Any pics of this working ?
Old 11-30-2013, 09:04 PM
  #445
Empatho's Avatar
The stock oem c6 z06 wheels clear without using any spacers.
Old 01-07-2014, 03:39 PM
  #446
twoolley08's Avatar
With a 5mm spacer would it be necessary to put longer wheel studs on?
Old 01-22-2014, 07:53 PM
  #447
twoolley08's Avatar
Anyone?
Old 01-23-2014, 10:57 AM
  #448
Killer_Z's Avatar
the eibach's that i purchased came w/ longer studs. I would say yes you should get some.
Old 05-02-2014, 10:59 AM
  #449
92 camaro74's Avatar
Default front rotors.
Originally Posted by JasonWW
I'm not so sure. GM is always changing the part numbers as well as the prices.
hi john im looking to put 14" rotors on my 92 camaro.I got 20" iroc rims in it.can you help me out with out having to change my spindles. thank
Old 12-09-2014, 05:58 PM
  #450
88BlackZ-51's Avatar
What are these calipers worth to sell?
Old 12-18-2014, 07:48 AM
  #451
badformulaLS1's Avatar
Will 14" rotors off a gen 1 CTS-V work? Or do they have to be the C6Z rotors? I have a pair of gen 1 V rotors I got for free and can resurface them myself at work... Just would like to know if they are direct bolt on like the Vette rotors?
Old 12-18-2014, 07:49 PM
  #452
Empatho's Avatar
cts-v1s are 6 lug not 5, so I doubt it.
Old 12-18-2014, 10:29 PM
  #453
blaine123's Avatar
Should use a Gen V Camaro SS rotor and have it honed to fit so the entire pad will be on the rotor and the pads will wear evenly.
Old 12-19-2014, 07:08 AM
  #454
Oh ok these are not V rotors then cause they are 5 lug. They must be gen 5 Camaro rotors.
Old 12-19-2014, 10:05 AM
  #455
blackbyrd's Avatar
If they are 5th gen rotors dont they have slightly different bolt pattern like the GTO's
Old 12-19-2014, 11:42 AM
  #456
blaine123's Avatar
Yes. They fit, but they won't work if your want to use a larger diameter wheel stud. There is a post on why they are better:
https://ls1tech.com/forums/suspensio...ss-rotors.html
Why use the 2010 Camaro SS rotors instead of the Z06 rotors?
-So that the pad contact area is correct for the caliper pad combination, unlike the Z06 rotors where there is a substantial difference and over time will create a chamfer on the pads inner edge . Ultimately you are loosing braking performance since less pad is actually contacting the rotor surface.
-Spacer or washers for caliper are not needed. The caliper is perfectly centered over the rotor. This will also help with not needing a wheel spacer in some cases since the caliper is farther away from the wheel spokes. Still no guarantee as there are so many wheel back space options.
Disadvantages:
-You will have to have the center of the rotor that goes over the hub machined out to fit correctly. I took a stock rotor along with 2010 rotors to the machine shop and had them match the bore. I was only charged $20 for the pair.
-Lug pattern does not match perfectly but fit without any issues on stock setup. Still quite a bit of clearance but you may have problems if you went to a thicker over sized lug. Rotor hub thickness was the same as the stock rotors so no need to change lug length unless needed for spacer.
Old 12-19-2014, 09:06 PM
  #457
Are the CTS-V and 5th gen Brembos the same Brembos that come on a lot of other cars nowadays? Reason being is in addition to the free gen 5 rotors I also got some free brake pads for a 2013 Infiniti G37. The calipers APPEAR to be the same as what the Vs, and 5th gens have, along with a ton of other cars that I'm seeing the 4 piston Brembo/14" rotors on lately. So do you guys think the pads will work with CTS-V calipers? If they are the same caliper then they should right?
Old 09-24-2015, 09:53 PM
  #458
ItalianZ28Stallion's Avatar
Nice thanks
Old 07-17-2016, 03:16 PM
  #459
Formula42's Avatar
Make sure you order parts from Flynbye in advance. Ed is not the fastest guy getting them out.
Quick Reply: Super Cheap Big Brake Kit - Info
