Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 10-26-2016, 08:26 AM
  #741
aggiebutter's Avatar
Originally Posted by Drop Top Kenny
2010 Camaro SS rotors (Autozone has them for around $58.00 each)
*You will need to machine out the center of the rotor to fit your hub. 71 mm I believe......it is in the write up (page 33 top post)
Just call KORE3, tell them what you are doing and they will set you up with the right brake lines.
Thanks,
Do you know the reason for not going with the Z06 Rotors ?
Old 10-26-2016, 11:29 AM
  #742
dojob's Avatar
Originally Posted by aggiebutter
Thanks,
-pads hang off c6 z06 rotors
-washers are needed to center caliper on c6 z06 rotor
Old 10-26-2016, 12:11 PM
  #743
Thanks!
Old 10-31-2016, 10:08 PM
  #744
M4N14C's Avatar
Here's my setup:
Thought about putting some "brembo" decals on the calipers but for some reason I really like that clean look.
Old 11-01-2016, 02:56 PM
  #745
Question... Is there a certain dimension (spec) that the camaro rotors need to be milled to ? I want to get the machining done before I take the current rotors off the car.
Old 11-05-2016, 08:45 AM
  #746
No Juice's Avatar
Originally Posted by M4N14C
Here's my setup: Thought about putting some "brembo" decals on the calipers but for some reason I really like that clean look.
Size and offset of these forgestar wheels ?
Old 11-08-2016, 02:01 PM
  #747
StoneColdLT1's Avatar
So an unfortunate update about wheel options. I know a lot of guys were running OE Wheels black chrome spyder replicas (18"x9.5" 40ET). They were a very cost friendly option and you didn't need to deal with spacers to fit them. I was planning on purchasing these in the spring to use on my setup as I just started buying parts.
OE Wheels just updated their website and I couldn't find these anymore, I emailed a sales rep and he confirmed that they are discontinued.
Old 11-08-2016, 03:52 PM
  #748
M4N14C's Avatar
18x11 with +40mm offset.
Old 02-15-2017, 08:24 AM
  #749
Default Which Spacer is needed for these ?
I have these 2008 Corvette wheels on my TA. Can you tell me which spacer I need ?
Old 02-15-2017, 03:51 PM
  #750
dojob's Avatar
tough to say, spoke shape counts just as much as offset
Old 02-17-2017, 07:44 AM
  #751
Anyone running these wheels ^^ ?
Old 02-17-2017, 08:44 AM
  #752
Aggiebutter, if you can't find any concrete info and you're definably set on doing CTS-V brakes, order the calipers, take you wheel off and just line up where the V caliper with mount the best you can and get a ballpark measurement of how much the CTS-V caliper sticks past the stock caliper. With that, you should have enough info to get a spacer in the ballpark that you need. If you need to get another spacer to gain a little extra space or maybe bring the wheel in a bit, tbh it's the cost of doing business when you do big brakes, but another set of spacers is a lot cheaper than a new set of wheels.
Old 02-17-2017, 08:47 AM
  #753
Aggiebutter, actually now that I think of it, I have a set of CTS-V calipers in the box ready to go on in the spring, and I have a set of stock 98-02 calipers I got with my spindles. I'll take some photos and measurements for you later tonight or tomorrow to help you get started.
Old 02-17-2017, 08:59 AM
  #754
Thanks! That would be perfect
Old 02-17-2017, 09:09 AM
  #755
dojob's Avatar
Also, once caliper is on, you can just play around with washers to get an idea of needed spacer thickness.
Old 02-17-2017, 08:20 PM
  #756
Default 4-Piston CTS-V's vs. 2-Piston LS Backspacing
Pics are in, for the record these are a 4-piston Brembo from a 1st gen CTS-V compared against a 98-02 2-piston LS Style F-body caliper.
Luckily I had a try square that could stand on its own while I held the tape and took photos. Anyway, measuring from the mounting flange to the square on the CTS-V's gave me a measurement of about 4-5/8"
Still have my sweet holiday table cloth on my dining room table.
For the F-body calipers, i pushed them together as best I could to simulate the farthest that the floating caliper would protrude towards the back of the wheel, it'll usually be this way after some fresh pads are put on and move father away as they wear down. From the same mounting flange to the square I got about 3-3/4"
Calipers were a little dirty, had to throw a paper towel down to protect that table cloth. I used a little package some drain plug seals came in to level the caliper the best I could.
So with that, you're looking to move that wheel approximately 7/8" outward in order to have about the same amount of space between the back of the wheel and Brembo's as you do now with the LS calipers when they're fully pushed together with fresh pads.
Understand that Brembo's are fixed calipers and can fit pretty tight to the back of a wheel, usually a lot tighter than a floating caliper that's stock so you may actually end up with a spacer that works that's a lot less than 7/8", but a spacer around that size is not a bad place to start when you first put the calipers on, then once you mount your wheel, if you have a ton of space, measure and move down in size.
Old 02-17-2017, 08:38 PM
  #757
Default 4-Piston CTS-V's vs. 2-Piston LS Backspacing Continued
Even better, don't know why I didn't think of this. In case your pads are worn down a bit, I measured just the LS mounting bracket, the fixed part of the LS's floating calipers. From the mounting flange to the edge it's about a hair past 3", 3-1/16" if you want to get ****.
So to help get a little closer with the spacer, the difference between the fixed Brembo caliper and the fixed LS bracket is about 1-5/8". So measure the closest part of the wheel to the front of that bracket (it should be less than 1-5/8", if it's more than you shouldn't need a spacer), subtract that from 1-5/8", add 1/4" for some space between the wheel and calipers and measuring error, and that should get you in the ballpark of your desired spacer.
Old 02-20-2017, 08:07 AM
  #758
Thanks a bunch Stone Cold !
Old 02-20-2017, 05:15 PM
  #759
No problem. When you get everything on and figure out what works, there is a fairly recent sticky https://ls1tech.com/forums/suspensio...come-here.html Post some pictures and specs. That sticky seems like a great resource but hasn't seen much action since it was created.
Old 03-13-2017, 12:04 PM
  #760
For anyone searching, I went with the 25mm spacer and it worked perfectly .
Quick Reply: CTS-V Brake Install w/ Pics
