Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 09-08-2009, 04:52 PM
  #121
Wesmanw02's Avatar
Originally Posted by monzaman44
Wesmanw02,
Do you know of anybody who has installed the CTS-V/Z06 Brakes on a Ford 9inch housing? I plan to do an around upgrade and you cannot beat this kind of quality and performance at this price.
Again, thanks
monzaman44
Nope, can't say that I do. Haven't heard of anyone installing these brakes on a solid rear axle. The main issue would be with the mounting bracket, if you can fabicate a bracket that spaces the caliper properly over the rotor in terms of diameter and side to side spacing, I can't see why it wouldn't work.
Old 09-14-2009, 08:56 PM
  #122
Yank423's Avatar
I'm Interested in this upgrade and have also been looking into some Comp.Grey 09 Spyder wheels 18x9.5 (all corners)after reading this thread i'm thinking about goin with the wheel offset of 40mm vs the 56mm.(no spacers needed hopefully) I wouldn't mind the wheels brought out a bit anyway with the 40mm but concerned it may be to far. (not flush) I'd run 275/40 18 tires on all. Thoughts??
Old 09-14-2009, 09:39 PM
  #123
Wesmanw02's Avatar
Sounds good to me. The 40mm offset should clear the brakes just fine, as long as the spoke design of those wheels doesn't protrude inwards near the caliper. They shouldn't stick out too far seeing as the stock 56mm offset is actually pretty far inwards, so 40 should put them right in line with the edge of the fenderwells. Tire size sounds about right for those width rims as well.
Old 09-18-2009, 11:55 PM
  #124
no title here
skyhighsami's Avatar
What are the options for the back? I was thinking about what would be a good brake setup for the car but I would like to upgrade the rears as well.
Old 09-21-2009, 05:01 AM
  #125
Zeppelin's Avatar
When doing this conversion and using the stock C6Z rotor, was there any concern that the stock C6Z rotors are not directional? I know the track guys sometimes have heat issues with the right side since you are running the cooling vanes backwards(they are actually 2 left side rotors). Any concern with this using them on the street hard?
BTW, just purchased my C6Z calipers, and am researching rotors. Great writeup.
Old 09-21-2009, 09:32 PM
  #126
Wesmanw02's Avatar
Originally Posted by Zeppelin
When doing this conversion and using the stock C6Z rotor, was there any concern that the stock C6Z rotors are not directional? I know the track guys sometimes have heat issues with the right side since you are running the cooling veins backwards(they are actually 2 left side rotors). Any concern with this using them on the street hard?
I haven't had any issues with mine under hard street use, and that includes repeated hard braking on multiple occasions. I've pushed these brakes as hard as I could push them without issue.
The directional cooling fins really only become a concern under extremely hard track use.
Thanks, good luck with the conversion.
Old 09-21-2009, 10:37 PM
  #127
JasonWW's Avatar
I've yet to hear of any heat related issues concerning the different vane directions. A lot of speculation, but no actual issues.
Anybody tracking their car hard should probably run brake ducts and that makes vane direction a non-issue.
There are also 2 other brands of rotors if your not comfortable with the OEM ones.
https://ls1tech.com/forums/suspensio...-kit-info.html
Old 12-25-2009, 03:35 PM
  #128
CarnivorWS.6-01's Avatar
OK this seems like the setup I need to go with. The way I read I should have no modifications if my offset is ok. I have HP Design Evo 18x7.5" I will check the offset I feel it is 41 or less. When I order my calipers from GM performance do I need to order the brake pad hardware as well? It does not appear that the rotors are directional am I correct? Is there anything else I need to consider? I did not read every post.
Old 12-25-2009, 08:59 PM
  #129
Wesmanw02's Avatar
The issue is that "41mm or less" offset only applies to a 9.5" wide wheel. The actual distance changes depending on width. So being that your wheels are 2" narrower, you will have less clearance between the brakes and wheel spokes.
If you order the calipers from GM, then yes, you will need to order the brake hardware as well. The rotors are not directional. See the first post in this thread for all the requirements for the swap.
Old 12-29-2009, 01:43 AM
  #130
LastBlack02SS's Avatar
Anybody try the CTS-V Calipers on the rear? I just got a front and rear set for my 02 Camaro.
Old 12-29-2009, 02:04 AM
  #131
cookba's Avatar
To Yank423 in post #122, 275/40/18 is gonna throw the speedo off and may rub up front. 275/35/18 should be what your looking for.
Old 12-30-2009, 03:55 PM
  #132
Anti-Venom SS's Avatar
Great write-up!!! Glad it's a sticky!
I'm very interested in this conversion, but I have a set of 15x3.5 Weld Draglites in the front... Think spacers would do the trick to get the rotors/calipers to fit behind the wheel?
Old 01-05-2010, 12:32 PM
  #133
Sk8phreak88's Avatar
This thread is a Love/hate topic for me!
I just finally decided to go with a 17" wheel combo.. But now I Find this and I need atleast an 18" wheel to fit..
Man.. Decisions decisions!
Great write up none the less!
Old 01-06-2010, 12:01 PM
  #134
Wesmanw02's Avatar
Sorry man no idea on that one...you'll probably just have to do some measurements and test fitting to see if you can make it work.
Old 01-31-2010, 01:46 AM
  #135
01Blk*SS*'s Avatar
do you have the part number for the '07 cts-v front left/right calipers? also i heard they come with pads for a little higher price, are these pads worth buying or can i get a better set for street use?
Old 01-31-2010, 02:21 PM
  #136
Wesmanw02's Avatar
These are the two numbers I came up with for calipers from GM Parts Direct:
89047726
89047727
I believe those are just the calipers themselves, no hardware or pads included. So in other words, they are not "loaded".
I got mine with pads (they were take offs, not brand new) and the pads are very good for street use. They are quiet, stop extremely well, and they grab well regardless of temperature. Their only downside is that they dust like crazy, so you constantly need to clean your wheels. Aftermarket pads like Hawk Ceramics would probably be a better alternative if you're looking for less dust.
Old 02-09-2010, 02:01 PM
  #137
josepy121380's Avatar
I just bought all the parts to do this upgrade. Total is $503. Thats a good deal in my book for this. Now my car might actually stop.
Old 02-09-2010, 08:41 PM
  #138
Wesmanw02's Avatar
Its an amazing deal for what it costs. Your car should stop like a race car after you're done.
Old 02-10-2010, 11:36 AM
  #139
No Juice's Avatar
Can you post a comprehensive list of parts, part #'s, cost per part, and place of purchase? This way we have all the current info.
Thanks
Old 02-11-2010, 06:31 PM
  #140
Yeah i am pretty gassed to get my car home from storage.
Quick Reply: CTS-V Brake Install w/ Pics
