Heater Hose Mod Writeup - Page 8 - LS1TECH
Thread Tools Search this Thread
Old 02-19-2015, 09:15 PM   #141
TransAm P's Avatar
Ill be doing this later on this month!
TransAm P is offline   Reply With Quote
Old 03-21-2015, 08:19 AM   #142
Just did this mod and it looks soo much better. can't wait for this snow to be gone so I can get the car back out on the roads.
CanadaHawk is offline   Reply With Quote
Old 04-12-2015, 12:52 AM   #143
Dave Simkus's Avatar
Newbie question. I got the half inch hose to do this mod because the space between my wheels and the body is so huge I can freely fist it with my hand lol it just looks aweful. Anyway, I put the rear on two Jack stands, remove the wheels and then what? I don't want to die an undignified death having a spring jump at my face when removing any bolts there. People say the spring just falls out? This is the only thing keeping me from trying this mod.
Dave Simkus is offline   Reply With Quote
Old 04-12-2015, 01:30 PM   #144
The rear suspension has the hang free, then you really should be able to wiggle those out, no bolt removal needed. If they are snug, I would use a spring compressor to compress them and they should fall out.
666ws6 is offline   Reply With Quote
Old 04-25-2015, 07:16 PM   #145
007FJ's Avatar
You will need to pull the rear shock nuts and remove the lower shock to allow the rear end to hang low enough. The jack stands go under the frame at the front of the LCA. Depending on your exhaust you will also have to pull the passenger side tire to fish that spring out. Going back together will be real easy without the isolator.
007FJ is online now   Reply With Quote
Old 06-25-2016, 01:14 PM   #146
Quote:
Originally Posted by hitmanws6 View Post
from the ground to the top of the wheelwell: 27"
from the centercap to the wheelwell, 15"
from the ground to the bottom of the body, 6"
from the ground to the bottom of the wheelwell, 10.5"
I checked my measurements on what I thought was a stock height SS. My car is 15" from center of wheel to fender. On passenger side and 15.5" on drivers. Front is 16.25" on drivers side and 16" on passenger side. Looked up into the spring and it appears the stock isolator is there still. Car has 102k miles on it. So what front springs would I need to level it out as the front does sit higher.
Guessing stock isolator could be worn out.
power5 is offline   Reply With Quote
Old 06-28-2016, 10:33 AM   #147
kenyanr1's Avatar
Has anyone done this mod to raise the rear a bit? My eibachs sit just a tad too low and I would like about a 1/2-3/4 inch lift if possible. If so, should I go with the thickest hose I can find?
kenyanr1 is offline   Reply With Quote
Old 06-28-2016, 11:36 AM   #148
Quote:
Do you still have stock isolators? 3/4" raise may require a hose inside a hose. Not sure if there is enough space between coils though. Could go get a hockey puck, cut it in half, and put it above the stock isolator.
Old 06-28-2016, 01:15 PM   #149
kenyanr1's Avatar
Quote:
Still got the isolators on. Thought about spacers also
Old 12-26-2016, 06:11 PM   #150
Thanks for the write up, I know it's an old post but I still appreciate it being here. I did mine today.
Before:
After:
6.0.2001.TA is offline   Reply With Quote
Old 12-26-2016, 07:10 PM   #151
kenyanr1's Avatar
Quote:
Before:
After:
I actually like the before and after
Old 12-26-2016, 07:11 PM   #152
LOL, thanks!
Old 12-30-2016, 10:57 AM   #153
Quote:
What does this do to the lower control arm angle?
chuckclanton is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
First LT1 with side splitters hitmanws6 Appearance & Detailing 76 04-14-2011 02:59 PM
C6 ZO6 Spyders on my Trans Am hitmanws6 Wheels & Tires 43 03-07-2011 06:25 PM
My LT1 badge came today! hitmanws6 Appearance & Detailing 20 08-28-2009 02:04 AM
Paint Ram Air hood red or black? hitmanws6 Western Members 6 06-26-2009 11:19 AM
Rear SLP Bilsteins/Heater Hose mod done hitmanws6 Appearance & Detailing 24 06-10-2009 01:34 PM
Tags
1999, 76, 97, camaro, firebird, heater, hose, hoses, kit, locations, ls1, mod, pontiac, ss, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
