m6 qa1 guys come help a fella out
Old 07-19-2009, 01:06 AM
BIG_T's Avatar
Default m6 qa1 guys come help a fella out
i have the single adjustables. im curious what u guys use on the front and rear at the track. on the front i have used 1-2 and the rears are on 6. i tried 12 on the rears and it slows my 60's down by .12 best 60ft time is 1.689. 4:11 gear, 9in, full adjustable suspension car. i know it has more than a 1.68 in it so im curious to what setting u guys are using. raceweight is 3170ish. a buddy of mine who use to have a auto car swore by 3 on the front and 3-4 on the rear when he went to the track. now i know the a4 car gets less shock just curious on if i can dip down in the lower 1.6's just from different settings
Old 07-19-2009, 02:41 AM
BIG_T's Avatar
been doing alot of good reading on ls1 tech. most say 2-3 f and 5-6 dr and 6-7pr. maybe i need a tad more gear. the old m6 bolt on record car cut high 1.5's and his only difference than my setup was stock rear struts, bmr upper and lower a arms, 4:33's, and the spohn dragbar. now he was 70lbs lighter than me too. my suspension setup for those who can help me figure this out.
-pa racing chomoly k member
- qa1's all 4 corners (single adjustables)
-cut rear v6 springs
-chomoly double adj. panhard and lca's
-lca brackets
-bmr extreme tq arm
-bmr subframes
-spohn 1in rear sway
rear: 9in, 4:11's, 26x11.50 et street (bias)
all the rear adjustments (phb, lca's, tq arm) are dead on thanks to collin btw
here is the car for reference
Old 07-19-2009, 10:16 PM
INMY01TA's Avatar
4:56s and 28' tires will help alot.
Old 07-20-2009, 02:00 PM
BIG_T's Avatar
wont a 28in tire slow my down at my 320rwhp level?
Old 07-20-2009, 03:02 PM
Duffster's Avatar
depends on your gear ratios. . . but if you're running 4.33, 28's will help over 26s
I've got a 1.60 60' on 4.30 and 28s with a 4500rpm launch...
Good luck.
Quick Reply: m6 qa1 guys come help a fella out
