K-Member ???'s
Old 10-25-2009, 09:41 PM
TX_Stang4lunch's Avatar
Default K-Member ???'s
How much does a tubular K-member help you ?
Tubular A-arms ?
Any advice is highly appreciated.
Old 10-25-2009, 10:13 PM
curtisad's Avatar
it saves about 35 pounds off the front of your car. Nothing else really.
Old 10-25-2009, 10:33 PM
is it worth the money .... b/c i can get the same weight savings replacing my seats with lighter racing seats ( and they have the wow facter too ).
Motor is out of my car ...soo it wouldnt be any more work really.
Old 10-25-2009, 10:45 PM
Parasoth's Avatar
Well, if you get seats, and a k member, then you have both weight savings. If it is a choice between the two, I would go with seats immediately if it's a stock/NA build car. K-member if I needed room doing a turbo build. But hell even then most people get by with the stocker for most turbo applications.
Old 10-25-2009, 11:23 PM
yeah .... just didnt see any significant advantage... so i wanted to make Sure i wasnt missing anything.
Old 10-25-2009, 11:45 PM
Kevin01Z28's Avatar
More room to remove headers. Allows the engine and trans to sag more when the crossmember is unbolted which makes those PITA top bellhousing bolts a little easier to get to. All I can think of really. It looks cool in red..
Old 10-26-2009, 05:55 AM
UMI Performance's Avatar
Hello,
A tubular K-member and A-Arms are a great weight reduction item. They also offer additional adjustment for caster and camber. The K-member frees up a lot of room under the hood for headers and a turbo's as well.
UMI offers a very nice front end set-up. If you would have any questions please contact us and we are glad to help.
K-member- www.umiperformance.com/2320
Thank you!
