Strano Spring owners: I need your pictures
I think they all look pretty similar, but as was mentioned, no two cars are alike. Some weigh more, some weigh less. Some have bigger rear axle tubes which make the rear higher. Some have added weight in the rear with bigger stereo's. Some have weigh reduction in the front. Some have aftermarket front lower control which can cause a height change.
And of course there are the things like light, angles, wheel size/offset and tire size that can also make things look different, even if two cars sit exactly the same height. But again, all these pics look pretty consistant to me.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Great shots guys... Thank you! Please keep 'em coming.
__________________
#32
Let me guess... you have a 12-bolt or a 9"? I'd guess so since your car sits higher in the rear than normal--and you have skinnies on the front. Have any other pics on street tires vs. drag setup? Just looking for stuff that shows folks what they are going to get for looks in a normal situation.
#34
Why can't it?
__________________
