Moog Lower Ball Joints...
Old 10-23-2009, 01:15 AM
2001redSS's Avatar
Default Moog Lower Ball Joints...
Took my car to get the ball joints replaced. I bought some Moog ball joints and told the guy I wanted them installed. He said they didn't look like they would hold grease and wanted to install the GM factory replacement. I told him to stick with the Moogs... I had seen people recommend them on hear and the guy at Advanced recommended them (He was one of the guys that work there that wasn't retarded.)
So my question is: any reality to his concern?
It's a small town mechanic who, I'm sure, doesn't work on these cars very often if ever. I've been leery of anyone in small towns ever since O'Rielly's back home tried to give me a flexplate for a Chevy pickup after I cracked mine in 3 places on my old Camaro SS.
Old 10-23-2009, 06:14 AM
UMI Performance's Avatar
The only thing we noticed with the Moog's is there boots are terrible, they are hard to get back on and don't seal real well... is this is the reason? I don't know... that is the only thing I can think of. Other than that they have grease fittings like any normal ball joint
Old 10-23-2009, 06:58 AM
Jeff Smith's Avatar
I agree with UMI about the Moogs boots are terrible badly. I cut it off and put new Energy Suspensions tie end dust boots. No problems with it for years.
Should I drill for grease fittings??
Old 10-23-2009, 03:20 PM
blk96406's Avatar
Default moog
I just put all new Moog balljoints and bushings in my front end about a month ago. Mine balljoints HAVE zerks to grease them, but I did change the boots to the Energy's cause I didnt like how Moogs wouldnt stay seated.
Old 10-23-2009, 06:05 PM
leadfoot4's Avatar
Maybe Moog changed their boot design? I put Moog b/js in my car about 5-6 years ago, and the boots are still fine.
Old 10-24-2009, 08:49 PM
Dom
Dom's Avatar
What ball joints do you guys use in your A-Arms?
Old 10-25-2009, 08:15 AM
leadfoot4's Avatar
The Moog ball joint is the best one. If, by some chance, their rubber grease boots are no longer top notch, the best thing to do would be to get the ES poly grease boots and use them with the Moog b/js.
Old 05-15-2010, 07:36 AM
vincew1's Avatar
Sorry to resurrect an old thread but would anyone know which E/S poly grease boot would work best for the Moog Lower balljoint? I see they have a large selection of universal lower balljoint grease boots. I'm re-mounting my control arms this weekend. Part #?
leadfoot4 you still out there??
Thanks!!
Old 05-15-2010, 12:38 PM
sjsingle1's Avatar
i put moog lowers in mine............used ES poly boots top n bottom.......on tie rods 2
Old 05-16-2010, 02:11 PM
vincew1's Avatar
So if I understand this correctly you are using the poly tie rod end boots on the lower ball joints? Strange....
Old 05-16-2010, 03:38 PM
leadfoot4's Avatar
No, I think what he's saying is that he's using ES poly boots on the upper and lower ball joints, as well as the tie rod boots also. You know, "internet shorthand".....
I threw out the comment about using the poly boots on the B/Js, however ES doesn't list a "direct fit" part number for the 4th gen Camaro/Firebirds. However, they do have a "size chart" that you could use to find what you need.
I had my car apart for some work over the winter, and in the process I found the upper B/J boots were trashed. I used the ES chart to find some that were close enough in size.
Old 06-19-2010, 11:38 AM
myred98ss's Avatar
I'm having the same problem with mu Moog ball joint covers. It seems like switching to ES is the way to go - can anyone help us with a part#? I'm sure many people will need it like us down the road.
Old 06-21-2010, 02:37 PM
LS6427's Avatar
I'm about to do all Moog UPPER and LOWER control arm bushings..........that ES poly boots part # would be cool if anyone has it...for the Moog UPPER and LOWER ball joints.
So these ES poly boots just fit together with the Moog ball joints?
How about the control arm bushings by Moog....do they need anything special so they seal and fit properly?
Old 10-18-2016, 11:59 AM
ShovelMan's Avatar
Part numbers on the lower balljoints?
Old 10-19-2016, 10:25 PM
LS1121's Avatar
Here ya go.
K6145T
Quick Reply: Moog Lower Ball Joints...
