tsp duals. th400 swap
Old 11-02-2009, 10:35 PM
BBFROMAL's Avatar
Default tsp duals. th400 swap
ive searchd and can not find what torque arm setup i can run with me runing tsp duals and a th400 swap...
Old 11-03-2009, 04:19 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
I can help you out here. You can use our full length torque arm and a torque arm relocation crossmember. This setup will clear your duals and still allow you to use your turbo 400 and still retain a full length torque arm. Give me a call and i can set you up with a torque arm and crossmember package.
Attached Thumbnails tsp duals. th400 swap-ta001-small.jpg   tsp duals. th400 swap-tcc006-small.jpg
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-07-2009, 05:50 PM
BBFROMAL's Avatar
i will prob be making a order this week.
Old 12-07-2009, 08:19 PM
UMI Performance's Avatar
Hello,
Just another option for you. We designed our torque arm around the TSP system and in most cases it allows you to tuck the exhaust up tighter then you can with the factory torque arm. I posted a link below to this item as well as some pictures of this item installed with the TSP system.
www.umiperformance.com/2205
For the TH400 for also offer a torque arm mounting kit. It mounts to the torque arm and also adapts to the TH400. Here is a link to this item-
www.umiperformance.com/2213
If you have any questions regarding our products please ask. Thank you!
Old 12-08-2009, 12:09 AM
BBFROMAL's Avatar
is it me of is the driver side sitting lower than the pass side?
Old 12-08-2009, 12:14 AM
Raven02TA's Avatar
its not... the picture is a tad crooked.
Old 12-08-2009, 01:35 AM
ssvert99's Avatar
these are all good setups, however I offer a tunnel mount version torque arm with a crossmember designed specifically for the TSP duals. all chromemoly construction and includes a driveshaft loop as well. alot of guys running auto trans will benefit from a shorter length torque arm, especially on a drag radial. just another option for you...
Old 12-09-2009, 04:46 AM
BBFROMAL's Avatar
midwest is looking the best so far....
Quick Reply: tsp duals. th400 swap
