bilstein's on stock springs?
Old 11-26-2009, 09:50 PM
Jake_the_Snake's Avatar
Default bilstein's on stock springs?
was going to order some bilsteins soon for my 96 trans am. couldnt decide between the bilstein HD and the SLP Bilstein shocks. from what i understand, the SLP Bilsteins offer better handling and a softer ride, but are also designed to work with the Eibach springs(SLP Handling #2). i was curious to see if anybody on here has used the SLP Bilsteins on stock springs, and if so, have they run into any problems. from what ive read so far, it seems a few people have run bilsteins on stock springs, but they didnt specify which ones, so i was unsure. as stated earlier, the car is a 96 trans am, non ws6. the suspension package is fe2, if it makes any difference. also, i do not plan on lowering the car in the future, as my next project will be a longtube/true dual setup, so i'll need all the clearance i can get. thanks
Old 11-26-2009, 10:03 PM
wannafbody's Avatar
Standard Bilstein HD's are meant for stock springs. Front SLP Bilsteins were designed for SLP springs.
Old 11-27-2009, 12:25 AM
hitmanws6's Avatar
they are the same shock fyi, get the slps. they are cheaper
Old 11-27-2009, 12:33 AM
i know that the slp are simply revalved hd's but i wanst sure if anybody ever ran into problems seeing as its set for a higher spring rate?
as far as price, they seem to be the same. found em for 380 at afterthought auto, and thats probably what i was gonna go with but im just checking to be sure. fired off an email to sam to see what he thinks and if he's got any other recommendations
Old 11-27-2009, 01:15 AM
hitmanws6's Avatar
i talked to him about these shocks, he said there would be no problems. and summit sells them for 313 fyi
Old 11-27-2009, 01:23 AM
shows 424 for me
http://www.summitracing.com/parts/SLE-70008/
