Suspension help needed
I've got a few questions I'm looking for answers for. I'm going to be going with a dana 60 in the near future. I plan to run a race suspension with this setup and want to get some of the smaller stuff now but only want to buy once and do it right the first time. With the dana 60 am I going to need a shorter drive shaft ? I'm also going to be running true duals (H pipe) dumped under the back seats, so I need to know what will work under the car and what I can get now and put the dana 60 in later. If I get LCA's and brackets now could I run into problems later ? Also the right torque arm to use is very confusing right now. Basically I'm just wondering what pieces I can get now to put on the car w/o having issues with added parts down the road.
Hello
What I would suggest for your particular set up would be! I would go with a torque arm relocation cross member and a full length adjustable torque arm to allow you still fine tune the rear end pinion angle. What I take it you are going to have a custom exhaust made? If so below is a pic to show you where you are going to have to place the cross over so you do not have any issues. If you went with a LCA's and Relocation Brackets you will be just fine.
http://www.umiperformance.com/catalo...caaeaoqun1f6n5
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
LS1Tech Premium Sponsor
