Shelf Life of ATE Super Blue ? and brake fluid flush...
I actually have a can from a couple of years ago that I was supposed to use on a brake fluid flush but I never got around to doing that !
So, whats the shelf life ? Its never been opened.
And, how many cans do I need for a full brake flush ?
And the procedure is, passenger rear, driver rear, passenger front and driver front right ?
LS1TECH Sponsor
If it's never been opened it should be ok. I always recommend two liters just to make sure you have plenty, might skate by with one but if you need more standard fluid can be used, but will dilute the ATE.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
