Do i need LCAs ?
I write checks with my mouth that my ass can't cash
Do i need LCAs ?
okay so by the end of winter its going to have full intake and exhaust and SFCs with weight reduction, battery relocation ect...on M/Ts ...will LCAs help me or not ? because people around here are saying they will help alot and others are saying i dont need them...also will a PHB help me for the price >?
no one on here can tell you whether you need lower control arms or not. if you have wheel hop, you'll want them. since you're an a4 (judging by username) and probably on the stock stall, chances are you'll dead hook on the M/T's with bolt-on power. if there's no wheel hop or tire spin, then you don't need them.
for the price, they're a good idea. i like mine. if i were you i'd just wait and see, no use buying parts you don't need.
I have them with only some bolt-on's. I'm an m6 tho. They seemed to dull the wheel hop, but it isn't gone. I like them. Did I need them? I don't know, but I love working on the car and it was easy to do. Makes the underside of the car look better, but that's the best I can give you.
I like your sig pic creeper.
Hello
I noticed that you are asking about LCA's! And I just wanted to suggest to you that anytime you can replace the factory stamped pieces with a tubular solid version and a poly bushing will eliminate a good bit of your wheel hop. But it really depends on other factors as well such as spring and shock combo. But the drag radials will definitely help. Another option for you that I would highly suggest is a set of lower control arm relocation brackets. They allow you either stock ride height or lowered they allow fine tune the rear by allowing you to adjust the lower control arm. Now depending on if the vehicle is lowered or not we determine if you need a pan hard bar. If it is I would suggest going with a adjustable to allow you to recenter the rear. Below is a link to show you what all UMI Performance has to offer!
http://www.umiperformance.com/catalo...9smn9its2qg190
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
