Full front suspension rebuild
Okay, after dismantling the upper and lower control arms and inspecting a few of the parts, the ball joints aren't shot, but the boots are losing grease so it would be only a matter of time. Tie rods are tight as can be, but the boots have taken a beating.
I already have poly bushings and endlinks for my 32mm front bar, so that isn't needed.
So here's what parts I'm looking to get so far:
Each is hyperlinked to their respective part for further inspection.
Energy suspension front kit: ENS-3-3164R x1
Energy suspension tie rod boots: ENS-9-13101R x1
Moog caster bushing lower: MOG-K6490 x1
Moog caster bushing upper: MOG-K6689 x1
Moog lower ball joint: MOG-K6145T x2
Moog upper ball joint: MOG-K6462 x2
Tell me what you guys think.
And what am I going to need to do to replace the ball joints? I notice the upper is riveted into place, so I'll need to drill that out...
I personally would stay away from poly bushings except in the sway bar up front. Not sure what all is in the kit you specified.
Drill out the rivets for the upper ball joint. The lowers will have to be pressed out and pressed back in.
Instead of replacing the tie rod boots I would replace the complete tie rod w/ a quality piece while you are in there. It never fails that parts are fine today and need replacing tomorrow.
You will also need an alignment after all of this.
personally, if i were puttining this much work into front end suspension i would spend the money on a new front end package. UMI has nice front end susp pacKages starting out at like $850 or so. just a suggestion, but post up total cost when you're done. good info for future ref
Plus I have a V6, and already have a tubular front K-member.
This is the exact reason I just bought new LCAs. The inventory on these parts is getting lower...IMO its better to just replace the entire arm while these are available.
http://lawmotorsports.net/Chassis4.htm
The bushings are relatively easy. But the lower ball joint is a real bitch! Good Luck with whatever route you decide to take.
SDPC is the only local dealer, I did look on Hawk's third gen, and they're selling the pair of lower control arms for $100 but it's a tossup on the condition of the bushings.
I talked to my dad who has a local Hot Rod shop and said he can get all the bushings and ball joints done in only a few minutes as he has all the tools there.
And I mentioned a few times that I'm not wanting to go tubular on a daily driven car and also in a city well known for rough streets.
I'm placing the order tonight and getting this ball rolling again. Now I just need to get the rest of the engine done!
