phb install help
Old 12-25-2009, 10:17 AM
LT_WON's Avatar
Default phb install help
just got my single adjustable on car panhard bar today. one side has a poly end the other is a rod end. stupid question, which end goes to the passenger side of car which end goes to the driver? i know i got a fifty fifty chance of getting it right . just to save some time from guessing and gettin it wrong. merry christmas and thanks again suspension gurus. P>S> is a bmr piece.
Old 12-25-2009, 10:46 AM
mitchntx's Avatar
Put the poly end on the chassis side and the rod end on the axle.
Old 12-25-2009, 10:49 AM
chevy_eddie's Avatar
the poly side goes with the chassis, and the rod end goes on the differential.
Old 12-25-2009, 11:05 AM
LT_WON's Avatar
thanks guys. is anyone else running this particular PHB? does anyone have and pictures to share ive been searching with no luck. links are appreiciated.
Old 12-25-2009, 11:22 AM
mitchntx's Avatar
Why the change? Tire rub?
Lay the factory bar on the driveway, insert the bolts through it and then put the new bar through the bolts, adjusting the rodded end to align to the bolt.
This makes the two rods exaclty the same length, bolt to bolt.
If you need to adjust to fix a tire rub, then adjust appropriately.
Use loctite on the jam nut.
Old 12-25-2009, 02:04 PM
LT_WON's Avatar
wanted a little more flexability for drag and street performance. thanks for the tips, helps. got it up there. just kinda unsure on how to adjust the rod end. plus dont have a wrench bigg enough to fit nut. go figure. overall bmr makes a nice piece .
Quick Reply: phb install help
