metal brake line over axle....part #??
Old 12-30-2009, 01:25 AM
cals400ex's Avatar
Default metal brake line over axle....part #??
I broke the metal brake line that goes over the rear axle on my z28. i can't seem to find this part on gmpartsdirect. I need the metal one on both the left and right side. Does anyone know the part number?
Old 12-30-2009, 06:13 PM
leadfoot4's Avatar
I'll hazard a guess and say that it's probably not available, and that you'll have to make one up from precut lengths available at your local parts store....
Old 12-30-2009, 09:31 PM
cals400ex's Avatar
that is awesome. i will go to the dealer and see if i can find anything.
Old 01-01-2010, 01:39 AM
SS SLP2's Avatar
this info was posted by someone else on here a few days ago I have not had a chance to check it out
hope it helps, Johnny
""hard brake lines that runs across the rearend housing. After I priced a bender, flaring tool, fittings and the spiral armor that covers the tubing, I started looking for alternatives. I found the new stock GM lines were nicely priced and complete. $25.05 for both shipped from GMPartsDirect for 98-02 non-TCS brakes. Not bad IMO!
Drivers Side # 10289429
Passenger Side # 10289430"
Old 01-01-2010, 06:15 AM
DaddySS's Avatar
for the 2000, part numbers 10413182 & 10289432 - $7 & $9 respectively. the first number is a new number (superceded) and they are available.
Old 01-02-2010, 02:39 AM
cals400ex's Avatar
awesome and thanks for the help. i forgot to mention that i do NOT have traction control either so that may change things a bit.
is there any place that i can see every part number? gmpartsdirect, for example only lists some parts.
Quick Reply: metal brake line over axle....part #??
