front suspension popping when extended
My car was on a lift the other day and while it began to lift the car the front suspension started popping loud until the front wheels were fully extended. Car seems to ride fine.
It has no front sway bar, spohn k member, and qa1 shocks. I cant remember if it did if before the shocks/kmember install. Anyone experience this before?
Hey :
Its only your car nobody else ever has any problems!!!
Before I changed to an UMI front end (A Arms U/L, and K mem) my A Arm bushings were getting worn out and made all kind of noise when it went on a lift, pop and boing sounds from the front struts and A Arms sticking as the ball joints were worn as well. You might want to check all of them out. How many miles are on it?
Dub
When In Doubt Do Without
Dub
Good luck.
